unconfigure sflow
unconfigure sflow
Description
Resets all the sFlow values to the default values.
Syntax Description
Default
The default values for sFlow are as follows:
  • sFlow agent IP address—0.0.0.0.
  • sampling frequency—sample one every 8192 packets.
  • polling interval—20 seconds.
  • maximum CPU sample limit—2000 samples per second.
sFlow is unconfigured and disabled on all ports.
Usage Guidelines
This command resets sFlow values to the default values, and removes any port configurations, and any sFlow collectors configured on the switch.
The following command unconfigures sFlow:
unconfigure sflow
This command was first available in ExtremeXOS 11.0.
Platform Availability
